Phone Labels
Discussion in '3CX Phone System - General' started by RLester, Dec 16, 2012.
  1. RLester
    Feb 16, 2012
    44
    How do you guys handle making of the phone labels. I would be most interested in Grand Stream GXP's but really I just wanted to know how most do it. I have seen some systems come with software to manage this and you just print them out and apply to the phone. I did not know if such software is available from 3CX or the phone manufactures. Any information as always is appreciated.
  2. kesher
    Aug 3, 2009
    I've never heard of phone label making software. From what I've been told, clients generally print their own using Microsoft Word.
    Just a little bit of playing with font sizes involved.
    If you find some software, please post it here as i'm sure it would be useful.
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    We use DESI Labels. http://labels.desi.com/
  4. RLester
    Feb 16, 2012
    44
    That DESI looks good!! I will have to down load it and give it a try. I see they do not have the complete Grand Stream line covered so my work around could be helpful to anyone that has or can get MS Access that uses GS phones. I have set this up for GXP-2110, GXP2120 & GXP2020Ext.
    The only thing I ask is if someone makes this better and or adds more phone reports please pass it on and let me know.
  5. netswork
    Mar 11, 2011
    577
    We buy their labels for the Cisco phones and have for the Yealink in the past. Then we use their software to print on their labels. Its easy and looks pro. They are kind of expensive though.
  6. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    There are fillable PDF templates for all Grandstream phones (see their website). You will need to cut them however. For large deployments we print all the needed labels with a dye sublimation printer and then simply use the vinyl cutting plotter to cute them out.
