Phone line breaking in and out
Discussion in 'Windows' started by georgineirish, Jun 25, 2014.
  1. georgineirish
    Jun 25, 2014
    Hi all,
    I have been using 3cx for 3 weeks now for work, unfortunately, i usually hear customers on the other line telling me that I am breaking off. I am using Jabra headset on my laptop and all is okay with the headset, im using 3cx via callfire and there is also no problem with them, they are assisting me by rerouting my call path once in a while, however, i still hear customers telling me that the phone connection is not good.
    could it be 3cx problems?
    can anyone help me on this?
    thank you..
    10,742
    281
    So...what hardware are you actually having issues with?
  3. georgineirish
    Jun 25, 2014
    could it be possible that 3cx has something to do with it?
    im really not sure.
    or could it be my internet connection? im using a wired connection but with only 2mbps speed.
  4. leejor
    10,742
    281
    Anything is possible. It's just that you said...
    So what combination IS causing problems?
  5. georgineirish
    Jun 25, 2014
    thanks for replying on my post. i really had no idea on what's happening but I am considering an upgrade on my internet speed.
    In the meantime, let me give you some info on what has been done to try resolving the issue, i contacted callfire to see if something was wrong, so as I said, they rerouted my call path, i also erased all histories and cache of my laptop, im not using a wifi to ensure that the connection is more stable.
    i am using a jabra headset that works perfectly,
    everyitme im on skype or other online voice recorder, my voice was smooth etc, but everytime i am having my calls using 3cx, i am breaking up.
    i dont know what the problem is, maybe you can help me figure out.
    THanks.
  6. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Record the calls to find out if the leg between you and the PBX is a problem.. or perhaps if it is the PBX and the trunk. Helps split where you need to go hunting.
  7. leejor
    10,742
    281
    Skype may be more compressed that the Codecs that you are using, so it may not be having issues. There very well may be a bandwidth issue. It could also be something (hardware, or a network setting) that is causing the problem. Can this be duplicated from other phones/devices, or is it just you?
    If there is a switch, between your PC and the 3CX server, try to bypass it. Remove every other device on the network, and try a call. Easier said than done in many cases, but it is surprising what havoc other devices, that are not working properly, or set-up correctly can have. Confirm what codecs you are using all the way through, try to keep them that same.
