Phone Model and Firmware Version
Discussion in '3CX Phone System - General' started by brianoakes, Jul 19, 2012.
  1. brianoakes
    May 12, 2012
    95
    How is this information populated? The reason I am asking is I recently updated the firmware on my Polycom phones. I updated the bootloader and the sip version. So far, only 1 phone shows the correct version in the Phones section of 3CX. However when I look at the phones themselves, they are updated and current.
    Any ideas? Thanks!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,569
    302
    I had this issue too with Yealinks. It took about 4 reboots of the phones before all but 1 is now showing correctly.
  3. brianoakes
    May 12, 2012
    95
    Interesting. So far, about 10 reboots. Nothing updated. Just kinda curious, as they should be updated. Any other ideas?
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    I just upgraded a number of phones of various makes and models and I did not notice the issue. On a V 10 system I just updated 34 ATA devices and actually watched the screen update as they re-registered with their new firmware. What if you start and stop the phone system?
  5. unoa
    Oct 14, 2009
    22
    Yep, just give the PBX a kick if you are able to at a specific time. Although, I have never noticed this issue before from V8 to V11.
