Phone provision - vlan tag
Discussion in '3CX Phone System - General' started by tominski, Mar 19, 2013.
  1. tominski
    Mar 19, 2013
    I'm using Granstream phones with the 3cx system and wondered if there was a way to set the vlan tag via the provisioning process?
    Thanks, Tom
  2. kevin
    kevin Member
    Nov 23, 2006
    316
