Phone Provisioning defaults
Discussion in 'Ideas' started by giwm, Aug 14, 2017.
Phone Provisioning defaults 5 5 21votes
5/5, 21 votes
  1. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    The extended provisioning options with 15.5 SP1 are a nice step toward fewer custom templates. However, it'd be great to set our own default values for these options.
    For instance, my phones may always be on VLAN 300 (WAN PORT VLAN ID) and the PC Port almost always on VLAN 100. Right now they default to 1 and 1. If I could set all these options to my own defaults, it'd speed up the entire provisioning process significantly and eliminate me from having to hard-code things like the WAN PORT VLAN ID.
    Perhaps another tab on the Templates page?
    #1 giwm, Aug 14, 2017
    jwardlaw93, mikeimpo and Bkksleep like this.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
    You can setup vlan settings, with 15.5 sp1 within the console.
    My only work with default templates , and not custom
  3. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Yes, but you can't set a default. The default is always 1.
  4. Bkksleep
    Aug 15, 2017
    funny, i stumbled over this because thought exactly the same...
    also, defaulting / presetting the "interface" would be nice.
    in v14 i had my custom templates and just had to select phone type and all was set.
    now no need for custom templates but i have to set the VLAN, interface per phone, every time - prone to human error.
    #4 Bkksleep, Aug 16, 2017
  5. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Because of the lack of setting a BLF to a multicast, EVERY phone of mine has a custom template. So when I updated all my templates (reduced from 14 down to 7 with the Line BLF option), I had to manually go to every extension:
    • copy the MAC
    • delete the phone
    • add a new phone
    • choose correct new template
    • paste MAC
    • Edit time to 12 hours
    • Change indicator light to Voicemail only
    • Set up Voice vlan
    • Set up PC vlan
    A very time consuming change prone to human error. Because of that, I ended up hard-coding the time, indicator light, and voice vlan
    in my provisioning templates, as they'll never vary from those settings.
    Don't get me wrong - I think this is an excellent step in the right direction. I just think there is still a lot of room for improvement and look forward to SP2. (Maybe make changing templates easier? En masse?)
    dkeethler and mikeimpo like this.
  6. dkeethler
    Dec 30, 2015
    66
    19
  7. berl
    Sep 17, 2012
    8
    Please make a function for setting predefined sets of configuration or bulk-editing phones to apply new templates!!!!
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    - Background image setting
    - Internal / external ringtone differentiation
    - Default volume setting after provisioning
    - Multicast Listener (atleast the first entry)
    - BLF for Paging Groups (instead of using a Custom Speed Dial)
    and ability to set site or group defaults.
    giwm likes this.
  9. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Ah, yes... Add Multicast Listener to my list! I suppose that's just as important as Multicast paging. :D
    /me mumbles something about those going hand in hand.
  10. craigreilly
    Feb 1, 2012
    3,530
    298
    Multicast paging wasn't a big thing for me as I just used 3cx Multicast Paging Ring Group for it.
  11. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    We have to program it per phone through the templates because we can't multicast across the VPN. It works fantastic... just isn't 'supported' by 3CX.
