Phone provisioning issue
Discussion in '3CX Phone System - General' started by dom, Aug 14, 2013.
  1. dom
    dom
    Aug 12, 2013
    7
    I'm new to 3cx, but it seem to be pretty brilliant.
    I have run into one strange issue while trying to get phones to provision.
    We have Cisco SPA504G phones, and the guides say to set the provision URL in the phone to:
    http://192.168.5.1:5000/provisioning/$MA.xml
    which doesn't work, on investigation in IIS, i found that the provisioning files are actually located at:
    http://192.168.5.1:5000/provisioning/wccq2mgy2t/$MA.xml
    Only by forcing a re-provision to that address can I get the phone to provision. The phone then has http://192.168.5.1:5000/provisioning/$MA.xml as its provisioning URL, so it wont auto provision again.
    Surely something is wrong as non of the manuals mention a subfolder or the provisioning URL
    Thanks for your help!
    EDIT: running 3CX Free, looking to upgrade to a paid version very soon, and its version 12.0.31763.282
    11,073
    323
    You failed to mention which version you are running. Version 12 is still being "tweaked", Version 11 has been out for a while.
  3. dom
    dom
    Aug 12, 2013
    7
    thanks Leejor, its 12.0.31763.282
    Am I best to stick with 11 for the moment?
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Yes on version 11!
  5. leejor
    11,073
    323
    I believe that version 12 is still in Beta, with a number of updates/fixes/additions still to come.
  6. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    That random-looking folder name is indeed random to your own install.. added in v12 to prevent brute-force attacking your web interface for access. It "secures" the provisioning folder, which would be an issue when exposed to the outside world otherwise.
  7. dom
    dom
    Aug 12, 2013
    7
    Thanks guys, sounds like I am best to downgrade to version 11.
    I guess all the provisioning templates for version 12 need to be updated to support the random folder name.
