nasaw
- Joined
- Jan 2, 2017
- Messages
- 3
- Reaction score
- 5
I am trying to provision a Fanvil C600 using a customised template.
I copied the default template and saved it as a separate template. My only changes are hard coded BLFs.
I can provision ok using the default template. When I try to use the custom template by using the "+Add Phone" button and the mac address of the phone, it does not work. If I make the BLF changes to the default template instead, then it works.
My reason for doing this is to be able to provision different groups of phones with different BLFs.
Any ideas?
Any ideas?
