Phone Provisoning missing from Settings tab?
Discussion in '3CX Phone System - General' started by verta, Aug 19, 2013.
  1. verta
    Aug 19, 2013
    11
    Hi All,
    I've just installed 3CX SMB Edition at the company I work for. I'm currently reading how to modify the provisioning templates and all web guides say to go to Settings -> Phone Provisioning, however this link is greyed out and is un-clickable. I'm aware that I'm able to edit the ini files directly in the provisioning folder, however I thought there may be a simpler way from the Web GUI to do this. Is this supposed to be greyed out?
    For reference, I'm running 3CX PhoneSystem v12.
    Thanks,
    Verta
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    You can do this from the 3CX Windows Console on the server where 3CX is installed but not through the web interface.
  3. verta
    Aug 19, 2013
    11
    Thanks bardissi, I didn't think to check that - it works a treat.
