Phone Registration Help!
Discussion in '3CX Phone System - General' started by Alisdair, Feb 20, 2014.
  1. Alisdair
    Feb 20, 2014
    I am trying to register a remote phone, as far as I am aware everything is setup correctly, the firewall checker passes everything but I get the following error in the server activity log
    "Got REGISTER for foreign registrar: registrar host <sip:mad:myoutsideip:5060> is not mine!"
    The myoutsideip is my ip address from our broadband supplier and is static.
    Any ideas greatly appreciated!
    Al
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Under network - stun server do you have your external IP in the "static public IP" box?
    Also check under "advanced" "custom Parameters" and look for "CMExternalAddress" and "MSExternalAddress", it should have your external IP listed there.
  3. Alisdair
    Feb 20, 2014
    Awesome will try, we have an A record setup for name.websiteaddress.co.uk as this forwards to our 3cx server can I use that instead of the IP?
  4. netswork
    Mar 11, 2011
    577
    It needs the IP in those fields on the 3cx server for SIP reasons.
  5. netswork
    Mar 11, 2011
    577
    On the phone you could try the DNS name...I have never tried that though. Is your remote phone behind a nat device?
  6. netswork
    Mar 11, 2011
    577
    This link may be of help to you if you have not already looked it over.
    https://www.3cx.com/blog/voip-howto/remote-extensions/
