Phone setting - DND, how to transfer to VM?
Discussion in '3CX Phone System - General' started by RobLloyd, Oct 2, 2007.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I'm using Linksys SPA 942 phones. If I use the DND function on the phones to stop it from ringing if I'm in a meeting then I can't get a call transferred to VM at my phone.
    What I do - Press DND on the phone. If I call the extension from another extension it goes to VM. That's fine and works as expected.
    When I try to transfer a call from an extension to the extension w/ DND turned on it goes straight to VM. I can't transfer. A blind transfer disconnects the call.
    Log file:
    22:12:23.663 StratInOut::eek:nHangUp [CM104007] Call(12): Call from Ext.101 to 999 has been terminated by Ext.101; cause: BYE; from IP:192.168.2.109
    22:12:23.647 StratLink::eek:nHangUp [CM104001] Call(11): Ext.101 hung up call; cause: BYE; from IP:192.168.2.109
    22:12:19.569 CallStrategy::Transfer [CM104000] Call(11): transfer failed
    22:12:19.569 StratTransfer::initialize [CM008002] Call(11): Leg to be replaced is not linked!
    22:12:19.553 StratLink::Transfer [CM104002] Call(11): transfers Ln:10001@nV Test from Ext.101 to sip:100@192.168.2.8
    22:12:16.084 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ext.101 (192.168.2.109:16386) with Media Server (192.168.2.8:7020)
    22:12:15.944 CallConf::eek:nIncoming [CM103002] Call(12): Incoming call from 101 (Ext.101) to sip:100@192.168.2.8
    22:12:07.678 MediaServerReporting::RTPSender [MS004000] Call(11) Ext.101: (ACTIVE): Can't send RTP stream to 0.0.0.0:16384 destination unreachable
    22:12:03.677 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ext.101 (192.168.2.109:16384) with Media Server (192.168.2.8:7018)
    22:12:03.662 StratInOut::eek:nConnected [CM104005] Call(11): Setup completed for call from Ln:10001@nV Test to Ext.101
    22:12:01.459 CallConf::eek:nProvisional [CM103003] Call(11): Ext.101 is ringing
    22:11:58.052 MediaServerReporting::DTMFhandler [MS211000] Call(11) Ln:10001@nV Test: DTMF (RTP) from 69.67.248.5:35770 arrived. in-band DTMF tone detection is turned off.
    22:11:51.520 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ln:10001@nV Test :)35770) with Media Server (70.88.47.78:9000)
    22:11:51.427 CallConf::eek:nIncoming [CM103002] Call(11): Incoming call from 860345xxxx (Ln:10001@nV Test) to sip:1860740xxxx@66.23.129.253
    3CX Server - 192.168.2.8
    Ext 100 (w/ DND turned on) - 192.168.2.108
    Ext 101 - 192.168.2.109
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Anyone?????
  3. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Isn't that what it should do? If DND is on, the phone should not ring.
    I agree that a blind transfer should not disconnect the call it should go to VM also. That may be a 3CX issue.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Right - the phone should not ring. But you can't transfer the call to VM. If you call the extension VM picks up, but you just can't transfer because the calling extension goes right into VM.
