Phone Template Variables
Discussion in '3CX Phone System - General' started by discovery1, Dec 16, 2008.
  1. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    I'm looking at writing my own template for a phone, and would like to know if anyone has a list of all the available 3CX variables you can use in the templates.
    At the moment i can only see the 5 or 6 shown in the template documentation.
    John
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Go to the following location in your 3CX installation folder
    Example:
    C:\Program Files (x86)\3CX PhoneSystem\Data\Http\Templates\phones
    All the entries which are in the format something:%%this_something_Variable%% can be varied.
    Example:
    sip auth name: %%extension_auth_id%%
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Thanks Nicky
    I have managed to write a template for a phone.
    I'm doing some final testing before i post to the Wiki.
    John
