phone templates problems
mdages
Can someone explain me how to use individual customized phone templates in V15, because I'm doing something wrong or it don't work.
In V14 I could easily change the phone template in the extension configuration page. In V15 I don't see how to change the template.
Under Settings Template, I can copy a template and give them a new name. But, it seems not possible to edit the template in place of the configuration page. I found my copied template in filesystem under %programdata%\3CX\Instance1\Data\Http\Interface\provisioning\xxxxxxxxx\CustomTemplates\phones and edit it with a text editor.
It seems not possible anymore to change the template in extensions/phone provisioning config page. So I press on delete, next to add and could choose my individual template.
file.php
Under "phones page" I pressed on reprovisioning and phone restartet.
But still with the settings of the original template. Under phones there is button "+Config" that opens an "Edit Template" window. But editing isn't possible. I suppose it shows me the current used template of a selected phone and this isn't the one I have selected in the extension/provisioning tab.
Currently I don't see any other way to use customized phone templates. In previous V14 it was clearly and easy to use, but this new "Zero Admin" in V15 means really zero. :shock:
regards
Markus
Get 3CX - Absolutely Free!
3CX
