Phone time
Discussion in '3CX Phone System - General' started by jsadan, May 21, 2010.
  1. jsadan
    May 3, 2010
    91
    Is there a way to set a global time on 3CX that will update the time on all phones?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I provision the phones with a valid time server such as an exchange server or pool.ntp.org
  3. leejor
    11,285
    360
    Many phones are set individually (NTP server) and have no way to "take" the time settings from the SIP server. This had been suggested in the past but the phone still would have to be able to comply.
  4. johnmichael
    Apr 6, 2010
    48
    Not really sure if it is worth it but this is just my suggestion.
    I setup the 3CX Server as an NTP Server and this 3CX Server is also checking time from other NTP Server such as pool.ntp.org
    After that i set all our VoIP Phone NTP Server to the 3CX Server using IP Address.
    If you need me to explain further, just let me know. Very much willing to help.
