Phone will not stop ringing
aberry
Intermediate Cert.
Having an intermittend problem with an 'unsupported' IP phone. Every once in a while a phone will get stuck ringing. The only way to fix the issue, is to either reboot the phone, or call voicemail and force a call on the line. Here is the verbose log from the call that caused the neverending ring:
v=0
o=3891 8000 8000 IN IP4 172.26.102.134
s=SIP Call
c=IN IP4 172.26.102.134
t=0 0
m=audio 5004 RTP/AVP 0 8 9 18 101
a=sendrecv
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
02-Oct-2015 15:36:52.755 [CM503001]: Call(C:1351): Incoming call from Extn:3891 to <sip:[email protected]:5060>
02-Oct-2015 15:34:53.684 L:1350.2[Extn]: Terminating targets, reason: SIP ;cause=408 ;text="Request Timeout"
02-Oct-2015 15:34:53.684 Leg L:1350.2[Extn] is terminated: Cause: 408 Request Timeout/INVITE from local
02-Oct-2015 15:34:53.684 L:1350.2[Extn] got Terminated Recv 408/INVITE from 0.0.0.0:0 tid=b9140a659650756a Call-ID=ODM1Y2FjMjBlZWFhMzZmNGYyYmFiNDNiYTk0NDg5OTc.:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP 172.26.102.20:5060;branch=z9hG4bK-d8754z-b9140a659650756a-1---d8754z-;rport
To: <sip:[email protected]>;tag=4456925e
From: "REDACTED "<sip:[email protected]:5060;nf=e>;tag=4b45e57a
Call-ID: ODM1Y2FjMjBlZWFhMzZmNGYyYmFiNDNiYTk0NDg5OTc.
CSeq: 1 INVITE
Content-Length: 0
02-Oct-2015 15:34:53.684 L:1350.2[Extn] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=b9140a659650756a Call-ID=ODM1Y2FjMjBlZWFhMzZmNGYyYmFiNDNiYTk0NDg5OTc.:
From: "REDACTED"<sip:[email protected]:5060;nf=e>;tag=4b45e57a
CSeq: 1 INVITE
Content-Length: 0
02-Oct-2015 15:34:53.684 Session 370463 has failed in leg L:1350.2[Extn] ; Cause: 408 Request Timeout/INVITE from local
02-Oct-2015 15:33:50.623 Endpoint Extn:3891 has added contact <sip:[email protected]:5060> for device Dev(586):[sip:[email protected]:5060;user=phone / 3891]
02-Oct-2015 15:33:50.623 [CM504001]: Endpoint Extn:3891: new contact is registered. Contact(s): [sip:[email protected]:5060 / 3891]
02-Oct-2015 15:33:49.577 L:1350.2[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
02-Oct-2015 15:33:30.883 Provisional response arrived for session 370463 of Leg L:1350.2[Extn]
02-Oct-2015 15:33:30.883 L:1350.2[Extn] got Provisional Recv 180/INVITE from 172.26.102.134:5060 tid=b9140a659650756a Call-ID=ODM1Y2FjMjBlZWFhMzZmNGYyYmFiNDNiYTk0NDg5OTc.:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 172.26.102.20:5060;branch=z9hG4bK-d8754z-b9140a659650756a-1---d8754z-;rport=5060
Contact: <sip:[email protected]:5060;user=phone>
To: <sip:[email protected]>;tag=1881986813
CSeq: 1 INVITE
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Supported: replaces, path, timer, eventlist
User-Agent: Grandstream GXV3275 1.0.3.46
Allow-Events: talk, hold
Content-Length: 0
02-Oct-2015 15:33:30.882 [CM505001]: Endpoint Extn:3891: Device info: Device Identified: [Man: Grandstream;Mod: GXV Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXV3275 1.0.3.46] PBX contact: [sip:[email protected]:5060]
02-Oct-2015 15:33:30.882 [CM503002]: Call(C:1350): Alerting Extn:3891 by contact <sip:[email protected]:5060>
02-Oct-2015 15:33:30.881 UacSession 370463 has formed leg L:1350.2[Extn]
02-Oct-2015 15:33:30.781 [CM503025]: Call(C:1350): Calling T:Extn:3891@[Dev:sip:[email protected]:5060;user=phone] for L:1350.1[Line:10000<<360XXXXXXX]
02-Oct-2015 15:33:30.781 Route to L:1350.2[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=3e369306a4584b59 Call-ID=ODM1Y2FjMjBlZWFhMzZmNGYyYmFiNDNiYTk0NDg5OTc.:
INVITE sip:[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-3e369306a4584b59-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
CSeq: 1 INVITE
Alert-Info: <http://www.notused.invalidtld>;info=external
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
Content-Length: 280
I do notice the line in bold, but am not sure what to make of it yet. Has anyone else had a problem like this?
Thanks, TJ
One item that I noticed is :
This was some 20 seconds into the call, so am uncertain if the phone was into its normal registration or if it had some issue that caused it.
I also noticed that the same extension had IP 172.26.102.20 (To: <sip:[email protected]>), but I assume this to be the 3CX server given that when the call went to Vmail, the VM extension was also on that same IP.
You might want to look at the extension settings and see how the settings for re-invite and replace headers are set and then do some testing by toggling same. I do not know that this will help, but possibly?
Getting Started - Admin
YBow
Get 3CX - Absolutely Free!
3CX
