Phone wont provision after upgrade to V15
Discussion in '3CX Phone System - General' started by Stuart Taylor, Feb 9, 2017.
  1. Stuart Taylor
    Feb 9, 2017
    Hi All,
    Following an upgrade from v14 to v15, our Yealink T46G phones wont provision. Logged in to the phones and the server url points to: https://192.168.17.1:5000/provisioning/03xmprud5o
    After the upgrade the default port seems to be 5001, so changed the url to 5001 but it still won't work. Doing a bit of googling suggested that this provisioning folder should be in the programdata\3cx folder but I can't see it. I see a "provsubdir" under C:\ProgramData\3CX\Data\Http. Tried https://192.168.17.1:5001/provsubdir as the server url and still nothing following a re-provision.
    We also have a problem with phonebook not working on the handset itself although this has been a problem since version 14, when you go to 3CX phone book and press update on the handset you get a message "failed to download remote phonebook"
    The template shows the following:
    remote_phonebook.data.1.url = %%PROVLINK%%/yealink_phonebook.xml
    remote_phonebook.data.1.name = 3CX Phonebook
    But i don't know where the xml file is, or how it is generated. I see you can download to CSV on version 15.
    The system runs on Server 2012R2, windows firewall turned off.
    I do apologise for all the questions but only been with the firm 6 months and my previous phone system expience was mitel.
    Thanks,
    Stuart.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,443
    540
  3. sohc
    Apr 22, 2009
    24
    I do have the same problem. I think I stayed on v12 for a long time since I don't have problems on my phone. Sometimes, updating cause all this problems but that's the way we get new features.
    When I try to provision new handset, it just won't work. I have selected the template in the extension. The phone reboots but it hasn't applied any of the settings like the BLF. Since I can't provision the phone, the CTI won't work anymore.
    I still have handsets that have been provisioned in the old version, still running in their old firmware and their CTI is working fine.
    My problematic T48 is running on version 35.80.0.130
    Appreciate if you can advise how we fix CTI and phone provisioning.
  4. npereira@cbnco.com
    Sep 21, 2012
    32
    12
    I was told last week after a seminar hosted by a local distributor, that the yealink t4xS (s series) do not work with v15.
    I have yet to test it as I don't have S series yealink phone but just placed an order for 1 unit of T42S and T46S today. Should get them in next week and will test against v15.
  5. sohc
    Apr 22, 2009
    24
    I've got the T48G and T46G handsets, both won't provision even if I updated it to the recommended firmware.
  6. YiannisH_3CX
    May 10, 2016
    7,443
    540
    @sohc
    Are the phones local meaning are the phones in the same LAN/ subnet as the PBX or remote?
    If local do the phones appear in bold under the phones tab? ( they must be factory reset to do so)
    If remote are you using an SBC or STUN?
  7. sohc
    Apr 22, 2009
    24
    Hi Yiannish,
    It is in the same subnet, the phones and the 3CX server are in the same VLAN.
    When I click on re-provision, the phone reboots but it doesn't apply the changes.
  8. YiannisH_3CX
    May 10, 2016
    7,443
    540
    Try adding a BLF on these phones from the management console, click ok and then try reprovisioning again.
  9. sohc
    Apr 22, 2009
    24
    Hi Yiannish,
    I have added the provisioning url and changed the template in the 3cx to make it work.
    May I know which folder should I open to make changes in the provisioning file? There's 2 directory and both have the same files.
    C:\ProgramData\3CX\Data\Http\Templates\phones
    C:\ProgramData\3CX\Instance1\Data\Http\Templates\phones
    Thanks!
    #9 sohc, Feb 21, 2017
  10. GiannosC_3CX
    GiannosC_3CX Guest
    Hi sohc,
    Please try to download the provisioning file directly from your browser and let us know if it works. Note, you can use this url only if you are in the same Lan with 3CX Phone System.
    http://3CX-IP:5000/provisioning/%Prov-folder-number%/IP-PhoneMacAddress.cfg
    The provisioning file is generated on the fly upon request.
    The provisioning folder is located at C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning.
    If you need to make changes or create custom templates, the folder is located at C:\ProgramData\3CX\Instance1\Data\Http\Templates\phones
  11. jmtelecom
    Apr 15, 2009
    12
    did you try to disable Trusted Certificates in security?
