phonebook ldap integration
Discussion in 'CRM / Helpdesk / App Integration' started by Beholder, Jul 28, 2016.
  1. Beholder
    Jul 28, 2016
    I' m trying PBX trial and got some important question - how works phonebook ldap integration?
    Only search there when incoming number doesn't exist in local base?
    Or maybe i can import all AD user's contact information to local base and when periodically sync it?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Here you have information related to LDAP integration:
    http://www.3cx.com/docs/exchange-ldap-p ... directory/
    When an inbound call arrives and the contact is not matched against a local phonebook entry, 3CX can search in LDAP, and if a contact is found, it's copied to the 3CX public phonebook, so next time the match is done faster. This is useful to show the contact name when they call you.
    Kind regards.
