Solved Phonebook not downloading v15
Discussion in '3CX Phone System - General' started by jms, Jan 18, 2018.
  1. jms
    jms
    May 23, 2011
    42
    My Yealink T22s aren't downloading the 3CX address book.
    When I look in the phone web interface, the remote phonebook URL is http://10.20.1.7/provisioning/ftp8v8eq2x/yealink_phonebook.xml.
    The correct URL is http://10.20.1.7:5000/provisioning/ftp8v8eq2x/yealink_phonebook.xml. When I type that URL into a browser it retrieves the XML file.
    I tried changing the template files by putting the appropriate values in this section:
    #Configure the HTTP port (80 by default) and the HTTPS port (443 by default) of the web server. Both range from 1 to 65535.
    #Require reboot;
    network.port.http = 5000
    network.port.https = 5001
    (the network port values were blank before I added 5000 and 5001).
    It hasn't made a difference, even after re-starting the Management Console service and re-provisioning.
    How do I change the phonebook URL to include the port number?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @jms
    The provisioning url should be automatically generated when the phone is provisioned. Check that the provisioning link under extension settings / Phone provisioning included the 5000 port.
    What port did you use when the system was installed?
  3. jms
    jms
    May 23, 2011
    42
    Yes, the provisioning link is correct under extension settings.
    Originally the ports used were 80/443 but a while back I uninstalled and reinstalled using ports 5000/5001 and restored from backup.
  4. jms
    jms
    May 23, 2011
    42
    I just fixed this.
    When you hit Reprovision under Phones in the Management Console it doesn't reprovision properly.
    If you revert the phone to factory and provision from scratch it provisions properly.
    Looks like a bug in the Management Console.
  5. YiannisH_3CX
    May 10, 2016
    6,016
    420
    Glad to hear this has been resolved. The issue was probably caused when the PBX was re-installed with new http/https ports and the phones were not reset and re-provisioned. Locking thread as the issue has been resolved.
