Phonebook - ODBC Entries
Discussion in '3CX Phone System - General' started by GabrielVE, Feb 23, 2017.
  1. GabrielVE
    Oct 25, 2016
    31
    Hi All!
    I was able to delete all Phonebook Entries that we have with the help of the 3CX tool provided by Support..
    Configured Phonebook ODBC feature to capture contacts based on our existing database
    The ODBC is working as it's starting to populate caller information and adds them to the Phonebook entries..
    However, I'm seeing several duplicate entries, is this normal? or something that can be fixed?
    Thanks in Advance!
  2. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Oh Yes! entries are duplicating all the time here!
    I think I'd rather have an ODBC to the 3CX Database than n ODBC connection to mysql......
    PLEASE FIX!
  3. KarstenW
    Aug 9, 2016
    19
    I recognized, this happens, when there are empty values in the database.
    e.g. db
    ID | name | mobile | business
    1 | Doe | _____ |
    2 | Smith | 11111 | 22222
    Then Smith gets dublicated contact.
    I have similar problem, when one of the column is empty, I don´t get an entry to my contacts
    e.g. db
    ID | name | mobile | business or ID | name | mobile | business
    1 | Doe | 11111 |____________ 1 | Doe |______| 22222
    My caller ID is 11111 or 22222, I don´t get a contact entry to 3CX server.
    Only if all columns are filled with values like below, I get a result.
    1 | Doe | 11111 | 22222
    Is this a bug, can that be changed without any dummy values?
    #3 KarstenW, Mar 10, 2017
  4. KarstenW
    Aug 9, 2016
    19
    I am facing this issue with the double entries too, can this be fixed please?
  5. ags
    ags
    Jan 8, 2013
    9
    I confirm that this is a problem !!!!
    I have a db access.
    my connect odbc string is:
    select f_ragsoc as intestazione, IIf(IsNull(f_telefo), ' ', F_TELEFO) as telefono, IIf(IsNull(F_TELEF2), ' ', F_TELEF2) as telefono2, IIf(IsNull(F_CELLUL), ' ', F_CELLUL) as cellulare FROM client WHERE F_TELEFO LIKE'%%number%' OR F_CELLUL LIKE '%%number%' OR F_TELEF2 LIKE '%%number%'
    sometimes I find duplicates ....
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    I just did some tests. I filled all empty fields with a dot (.), so that they are not empty. Still I get plenty double records...
    HELP! HELP! HELP!
  7. dandersonn
    Feb 13, 2017
    7
    is this problem solved?
  8. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Yes, it is solved. I have a nice solution for my address book now.
  9. dandersonn
    Feb 13, 2017
    7
    And how did you do that?
