PhoneBook per extension group or disable phone book
Discussion in '3CX Phone System - General' started by Wolfraider, May 31, 2017.
  1. Wolfraider
    May 30, 2017
    7
    Is there a way to only show the members of the same extension group in the phonebook? We currently have 2 different companies in our system and we would like to keep the phonebook populated for each separate and not see all extensions. If that cannot be done, can we disable the phonebook all together?
    Brant Y likes this.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Wolfraider
    I am afraid there is no way to split the phonebook nor disable it completely, what you can do is select all extensions and click on edit, then navigate to options and select Do not show extension in 3CX company phonebook.
    You can also post this as a feature request to our ideas section of the forum where it can be upvoted by other users and evaluated by the appropriate departments.
  3. Wolfraider
    May 30, 2017
    7
    Will do, thank you
