Phonebook sync with LDAP not working
Discussion in '3CX Phone System - General' started by TheYves, Apr 21, 2014.
  1. TheYves
    Apr 20, 2014
    9
    I've installed 3CX Phone System v12 Professional Edition and now I'm trying to set up phonebook sync with LDAP but I just don't get it to work. I double checked the LDAP settings and they are definitely correct and I also enabled "Caller ID and Phonebook matching" with a minimum matching length of 6. So here are my questions:
    a) How can I debug the phonebook sync?
    b) How often does 3CX resync with LDAP?
    Thanks in advance.
    Cheers
    Yves
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Ensure your logging level is in verbose mode, restart services, wait for 5-10 mins for sync, then see log file : C:\ProgramData\3CX\Data\Logs\3CXCompanyDirectory.trace.log
    LDAP sync has been tested against MS Active Directory only.
