phonebook v15 Exchange 2010
Discussion in '3CX Phone System - General' started by ronecker, Nov 8, 2016.
  1. ronecker
    Nov 8, 2016
    Is there a way to use in v15 the Exchange sync of contacts with an Exchange 2010?
    We've been using it since v12 and where quite happy with it, but the latest version seems to dislike our Exchange
    Let me guess, it is deemed outdated?
    Taken from the 3cxSystemService.log file
  2. agesen
    Oct 17, 2016
    18
    In parameters of 3CX search for "CDM_EX_VERSION"
    Try enter Exchange2010
    Regards Nanna
  3. ronecker
    Nov 8, 2016
    Interesting idea, but no cigar.
    It was set at "Exchange2010_SP2", I tried "Exchange2010" and "Exchange2010_SP1" to no avail.
    We are at 14.03.0319.002 which translates to Exchange 2010 SP3 RU15 (read, the latest available), so the server supports it.
    I have a hunch, since v15 was rewritten, and there is no longer a selection of Exchange version in the corresponding form, they neglected to introduce the EWS schema version in their call. And since the latest version defaults to Exchange2013, this might explain our problems.
    Let's see what support has to say about this
  4. agesen
    Oct 17, 2016
    18
    The FQDN is case sensitive, so be sure thats 100% correct.
  5. ronecker
    Nov 8, 2016
    FQDN case sensitive, since when?
    Anyways, I am at all lowercases, which worked in the past and is currently working in any browser.
    Fiddeling around with settings, I can get an 401 not authorised, so I am guessing Exchange is answering, but does not like the EWS version.
  6. agesen
    Oct 17, 2016
    18
    Sorry I was mistaken - in 3CX FQDN is case sensitive when integrating with exchange UM, not the phonebook.
  7. decalabs
    Sep 21, 2016
    15
    I got the same problem. 3CX V15 with an older Exchange on a SBS2011.
    Did you make it work?
  8. smcore
    Mar 4, 2013
    There are responses by 3CX to this problem?
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,469
    283
  10. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    Hm, would You mind to support Exchange 2010 as well?
  11. nobody
    Aug 15, 2017
    77
    Actually I would expect that the 3cx Exchange and Outlook Support works for all Versions which are supported by microsoft. So, it should have work together with Exchange 2007 until April 2017.
    I do not understand why functionality that worked is dropped without notice
    Well, there is a workaround, which seems to works for me with 3cx V15 to reactivate sync contacts with Exchange 2010:
    The first step to do, is to enable basic authentication in the ews subfolder of IIS, without this, you might get an error message with the identical text to "Microsoft.Exchange.WebServices.Data.ServiceVersionException: Exchange Server doesn't support the requested version". Regardless of Exchange 2013 or 2010. Actually I did find this workaround because I still got this Error when I finally installed Exchange 2013, and contact sync did not work.
    Now, to solve the real problem:
    On the PBX server there are several copies of a file "Microsoft.Exchange.WebServices.NETStandard.dll"
    Copy the file to some other location.Open the copy with a hex editor. Search for "Exchange2013_SP1". Replace with "Exchange2010_SP1". Save.
    Replace all occurences on the pbx of this file with the patched version
    reboot pbx.
    Your Contacts will now sync with Exchange 2010 and above.
    Question: why did 3cx did not supply a patched version of the Library? Or Why did 3cx not already make a call which is compatible to 2010_sp1 and above?
    #11 nobody, Aug 15, 2017
