Phones not getting correct time
Discussion in '3CX Phone System - General' started by TSlocum, Oct 6, 2015.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    We've got Cisco SPA514g phones and when they auto-provision with DHCP Option 66, they don't get the correct time. They show 1/1 12am. The time on the server is correct and the time zone is set correctly in the provisioning options.
    What could be causing this?
  2. empower1
    Aug 2, 2010
    We were having the same issue but I found the resolution
    Assuming your phone is provisioned with the right Provisioning Template, do the following:
    3CX Phone System - Settings - Phone Provisioning
    Enable Day Light Savings Time
    I am in Australia, so these are my StartTime and EndTime
    StartTime: Month: 10 - Day: 4 - Hour: 0
    EndTime: Month: 4 - Day: 3 - Hour: 0
    Offset(Minutes): 60
    Save the settings and re-provision your phone from
    3CX Phone System - Phones - Re-provision Phone
    Good luck
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    I tried that and it didn't work.
  4. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    Check the management console
    Settings
    Phone Provisioning
    Time Settings
    Time Server
    default is
    pool.ntp.org
    This should be provisioned and be visible in the phone web interface and this is where the time should be coming from, along with your time zone modification and dst. If you are not getting a good date then you are probably not getting to a good time server.
    Allen
  5. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    I've tried pool.ntp.org, 0.us.pool.ntp.org (another ntp pool server here in the US), and the local DC, none of which work.
  6. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    Might want to examine your firewall(s) to make sure they are not blocking ntp traffic.
    Allen
  7. stalley
    Oct 8, 2015
    16
    My Cisco 7960s would never pull the time info from 3cx server (v12). I had to hard code it in their template, which seems to be working fine now. You phones are much newer than mine, but this is what worked for me...
    #Setting for Timezone and DST, Option GMT,CET,EET,...
    sntp_server: "10.10.10.65" (internal ntp server)
    sntp_mode: unicast
    time_zone: "%%param::time_timezone_cisco79x0%%"
    dst_offset: 1
    dst_start_month: March
    dst_start_day_of_week: Sun
    dst_start_week_of_month: 2
    dst_start_time: 02
    dst_stop_month: Nov
    dst_stop_day_of_week: Sun
    dst_stop_week_of_month: 1
    dst_stop_time: 02
    dst_auto_adjust: 1
    time_format_24hr: 0
    date_format : M/D/Y
  8. efounco
    efounco New Member
    Sep 28, 2011
    148
    First off, make sure NTP is defined and setup properly in the DHCP server settings. Next, use an internal NTP server versus a pool/public NTP server. Some phone are picky about resolving to external pool/public NTP servers through a firewall. Try using the IP address instead of the FQDN. This will eliminate any DNS issues you might have. Finally, don't use the 3CX out-of-the-box provisioning template for your phones. You can create a custom value that changes your daylight savings time without the need for micromanagement. For instance, we use (with our SPA504G):
    <Daylight_Saving_Time_Rule group="Regional/Miscellaneous">start=3/8/7/02:0:0;end=11/1/7/02:0:0;save=1</Daylight_Saving_Time_Rule>
    This setting adjusts the time changes automatically without the need of defining them every year in 3CX.
