Phones Not Registering After Update ( Cisco 7940 /7960 )
Discussion in '3CX Phone System - General' started by alex22alex, Mar 23, 2010.
  1. alex22alex
    Jun 11, 2008
    38
    Hello All,
    Slight problem thats driving me out of my head. We were running a really old version of 3cx (5.1.45) so i decided to plump and go for a fresh install of the lastest version ( on a new install of windows aswell). However upon setting the system up none of the phones will register ( cisco 7960's ). Server is on the same ip as setup in the cisco's.
    Nothing is showing up in the 3cx server activity log i.e failed authenciations etc ( logging set to verbose ).
    The phones are already setup from the old system with the correct sip settings.
    We do not use any other phones i have tested a softphone and it could connect to the extensions fine. Its driving me loopy
    Any ideas ?
    Cheers Alex
  2. comresource
    comresource Member
    May 22, 2009
    303
    You mentioned its a new install. Did you make sure that a TFTP service was installed with no firewall blocking?
  3. alex22alex
    Jun 11, 2008
    38
    Hi Danny,
    Thanks for the reply.
    I used a TFTP server to when loading the installtion files on to the phones. However this was when they were setup for the orginal install. Sincer i have setup the new 3cx install just like the old one or so i think i can't see any reason for a tftp server ( you can auto provision 7940/60's ).
    So i dont see any need to change the settings on the phones again or do you need a TFTP server for something i am missing ?
    Cheers Alex
  4. comresource
    comresource Member
    May 22, 2009
    303
    I do not knowTrixbox well enough to be sure if a configured 7940 will just automatically work on 3CX. You can try to telnet to the phones (if its enabled) and look over the settings.
