phones not staying registered
Discussion in '3CX Phone System - General' started by purvis, May 20, 2010.
  1. purvis
    Oct 26, 2009
    8
    I have some Zultys IP phones that I've got hooked up to a 3CX system for testing in preparation for purchasing a full license in the near future. I also have 3CXPhone installed on a PC. Each of them will eventually become "unregistered" on the server, and I have to reboot/restart to get them to register. Once they become unregistered, none of the other phones can reach them. Dialing that extension goes straight to VM. Any ideas?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    All ideas are described in http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
    Especially in case if 3CX phone "eventually becomes "unregistered" on the server"
  3. leejor
    11,126
    330
    Make sure that the phones are set to re-register every 30 minutes at least.
