Phones suddenly stopped working - Loops in Register, 407 Proxy Authentication Required
Discussion in '3CX Phone System - General' started by angeraer, Dec 12, 2017.
  1. angeraer
    Dec 4, 2017
    6
    I have some legacy Grandstream phones that I'm using in a POC setup to validate the 3CX solution.
    It was running, but suddenly it stopt working. A packet capture on the phone shows that the phone is sending the REGISTER towards the PABX (in the cloud). The PABX sends a 407 Proxy Authentication Required to inform the phone to authenticate and there it seems to stop and loop indefinitely.
    I know the phones aren't supported, but they worked for some weeks. I'm not aware of any changes that could have an impact on this and don't understand why the phone isn't passing the correct information.
    This is the capture information taken on the phone. The same behavior is seen on the PABX. I don't see any other logs that indicate where to look?
    Code:
    REGISTER sip:safevoip-demo.3cx.be SIP/2.0
    Via: SIP/2.0/UDP 84.193.162.64:5060;branch=z9hG4bK1607428337;rport
    To: <sip:002@safevoip-demo.3cx.be>
    Call-ID: 966236774-5060-1@IE.BJD.BGC.GE
    CSeq: 2034 REGISTER
    Contact: <sip:002@84.193.162.64:5060>;reg-id=1;+sip.instance="<urn:uuid:00000000-0000-1000-8000-000B82953DB2>"
    Proxy-Authorization: Digest username="o35dcho", realm="3CXPhoneSystem", nonce="414d53595a2f61e214:da510c9361a7deb240a60660249101c4", uri="sip:safevoip-demo.3cx.be", response="8d49c5190c9e12c969b50abec32c5d60", algorithm=MD5
    X-Grandstream-PBX: true
    Max-Forwards: 70
    User-Agent: Grandstream GXP2140 1.0.9.26
    Supported: path
    Expires: 3600
    Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
    Content-Length: 0
    SIP/2.0 407 Proxy Authentication Required
    Via: SIP/2.0/UDP 84.193.162.64:5060;branch=z9hG4bK1020916491;rport=5060
    Proxy-Authenticate: Digest nonce="414d53595a2f61e214:da510c9361a7deb240a60660249101c4",algorithm=MD5,realm="3CXPhoneSystem"
    To: <sip:001@safevoip-demo.3cx.be>;tag=dc5bcb01
    From: <sip:001@safevoip-demo.3cx.be>;tag=1310528689
    Call-ID: 975324043-5060-1@IE.BJD.BGC.GE
    CSeq: 2032 REGISTER
    User-Agent: 3CXPhoneSystem 15.5.6354.2 (6354)
    Content-Length: 0
    CSeq: 2034 REGISTER
    Max-Forwards: 70
    Supported: path
    Expires: 3600
    Content-Length: 0
    CSeq: 2032 REGISTER
    Content-Length: 0
    Same view on the PABX:
    Any idea where to look?
    Andy.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Check the IP Blacklist in case the Public IP of the location where the phones are at is in there. Also check if the Auth ID and Passwords are still the same, maybe someone re-generated them?
