Phones Tab - Multiple Registrations for Same Device
Discussion in '3CX Phone System - General' started by ucs1, Jul 10, 2016.
  1. ucs1
    Jun 21, 2013
    42
    I have over 120 of the same device showing in the phones tab. When a device re-registers, you would think we would drop the old binding ?
    Staff using the mobility client all have 3-4 phone showing as registered under the phones tab also, however they just have the one device.
    Basically I have pages of this for multiple users (but not every user)
    Code:
    333	3CX	Windows client CTI	3CXPhone for Android 14.0.57	Users Name	333	*****	*****
  2. pact
    pact New Member
    Dec 16, 2009
    202
    36
    We are seeing the same behaviour as well.
    Only 3CXPhoneClients, both iPhone and Desktop are adding, never disappearing.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, Yes its a problem but update your system in the next upcoming release and it will be fixed.
    Thanks for reporting.
  4. ucs1
    Jun 21, 2013
    42
    I haven't experienced this in v14 at all the ast time it was apparent for me was v12.5 sp1
  5. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    The bug was due that if client session terminates abruptly the session will remain alive on server side. Now in V15 if we see that the session is not alive, server will wait until 8 seconds and then terminates the session.
    If you had problems with V12.5 it could be something else.
    But I suggest you update guys if you are running V12.5 as we made heavy improvements in this area.
