PhoneSystem Queue Manager service terminated unexpectedly
Discussion in 'Windows' started by skinap, Jul 30, 2014.
  1. skinap
    Jul 30, 2014
    14
    Got some issue with 3CX phone server that 3CX PhoneSystem Queue Manager service terminated unexpectedly, the users can not log into queue and take phone calls, have to manually start the Queue Manager service in the server. Any idea please?
    Below is the error message I got from system log and application log, there is no obvious error appear in 3cx server activity log:
    .NET Runtime error ID1026
    Application: VCEHost.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.AccessViolationException
    Stack:
    at VCEHostNet.Call.PlayForeground(System.String[], Boolean)
    at QMgrPlugIn.PromptBuilder.PlayForeground(VCEHostNet.Call, Boolean, System.String[])
    at QMgrPlugIn.PromptsPlayer.PlayPrompt(Boolean, QMgrPlugIn.Prompt_Info[])
    at QMgrPlugIn.PromptsPlayer.Start()
    at QMgrPlugIn.Scheduler.ProcessTasks()
    at QMgrPlugIn.VCEHostPlugIn.ThreadFunc()
    at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
    at System.Threading.ThreadHelper.ThreadStart()
    Application Error ID1000
    Faulting application name: VCEHost.exe, version: 9.0.35264.0, time stamp: 0x539af204
    Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
    Exception code: 0xc0000005
    Fault offset: 0x000007fe9a147c2e
    Faulting process id: 0x8fc
    Faulting application start time: 0x01cfa7af806d8b20
    Faulting application path: C:\Program Files\3CX PhoneSystem\Bin\VCEHost.exe
    Faulting module path: unknown
    Report Id: 3df2cb6b-164c-11e4-bfe3-0050568600de
    Service Control Manager ID 7034
    The 3CX PhoneSystem Queue Manager service terminated unexpectedly. It has done this 1 time(s).
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Re: PhoneSystem Queue Manager service terminated unexpectedl
    Hi, are you running v12 with latest service pack (SP6) ?
    Are you up-to-date on all your windows updates and .NET ?
    Are you using supported operating system ?
  3. skinap
    Jul 30, 2014
    14
    Thank you for the reply, the server is running v12 with sp6; .net framework 4.5.1; Windows Update up-to-date; Windows server 2008 R2 Enterprise.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    I suspect some other software on same host preventing normal behavior can you run a tasklist in command prompt and post dump ?
  5. skinap
    Jul 30, 2014
    14
    Please check the attachment. Thank you.
  6. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    The only specific software I can see from your running processes is VoIPToys :
    VoIPToys3CXRelayServices. 2136 Services 0 58,376 K
    Please uninstall it and see if issues remains.
  7. skinap
    Jul 30, 2014
    14
    Thank you for the reply, will uninstall it and keep monitoring.
  8. Nachomama
    Aug 15, 2014
    11
    I have had this issue since early v11 on a very busy call center - seems to happen about 3-4 times a year where it will just crash
    Looks exactly the same as yours from event viewer
    Even worse is that it doesn't follow the destination so all incoming calls just fail
    I've changed their PC twice with fresh installs - when asking Tech support they asked me to disable AV software but that didn't help
    On v11 SP6 with windows 7 and all updates and it still does it... but it's so intermittent it's impossible for us to trouble shoot.
    Please post if you figure something out,. we've had to use SNMP and monitor the queue service so we can be notified when it happens.
    Last go around we set the service to try and restart in windows services - shall see.
