Phonesystem services not starting
Discussion in '3CX Phone System - General' started by koshy_vimal, Jan 13, 2009.
  1. koshy_vimal
    Jan 13, 2009
    15
    Hi guys,
    I had installed the free version of 3CX Phone system. but the following services does not seem to be starting:
    1) 3CX Phone system
    2) 3CX Phone system conference room
    3) 3CX Phone system digital receptionist
    4) 3CX Phone system media server
    5) 3CX phone system parking orbit.
    And i guess clients wont get registered with the server if 3cx phone system is not running. So is there any work around for this?
  2. ndl
    ndl
    Nov 5, 2008
    51
    you need to supply little bit more information for people to be able to help have a look here http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
  3. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Please ensure that you have run the 3CX wizard to the end after the installation. This need to be run before you can proceed to run the 3CX Phone system.
    Please check the event logs to see the errors for these services failure. All are probably failing since the 3CX Phone system has failed to start. Check out the event logs and see what reason does it give you for the failure of the 3CX Phone system service.
    regards
  4. koshy_vimal
    Jan 13, 2009
    15
    Thanks a lot guys. The problem was that I had another PBX system running on the same machine. I uninstalled it and now 3cx is working fine
