Phonzo.com - outgoing calls problem
Discussion in 'Android' started by MartinAM, Jul 11, 2010.
  1. MartinAM
    Jul 11, 2010
    Hello.
    I just started using 3CX brilliant software.
    when I try to use it with internetcalls.com SIP all works well. I can call with a success and great sound quality to stationary phone numbers in norway and Poland.
    I have also Norwegian Phonzo as my VOIP/SIP provider.
    I put all settings, and then I can't make outgoing calls.
    I can receive calls and call to mobile cellphone numbers, but when I try to call stationary numbers in Norway or Poland, I just can't. It says calling and then calling stops after 10 sec.
    Any idea what is wrong?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    Thank you for your feedback. I suggest you contact the VoIP provider to help you with this. I think they should test 3CXPhone for Android with their service....
