php email notifications (bug report)
Discussion in '3CX Phone System - General' started by onekit, Aug 9, 2007.
  1. onekit
    Aug 3, 2007
    27
    I receive emails with notification with such texts inside table:
    Notice: Undefined index: CALLER in C:\Program Files\3CX PhoneSystem\Data\Ivr\Templates\VoiceMail\Notify.php on line 56
  2. gbarnes
    Aug 3, 2007
    83
    Emaiol template.
    Hello.
    What version are you using?
    Do you get other information there also, eg a duration, the .wav file attachment etc.
    Does it always happen, or just on 1 message.
    It looks like the CALLER variable is not seing set, this can be turned off in the script to surpress the NOTICE, but I think it will be better to work out why this is happening first.
    Try adding this line to the file [install dir] / data / ivr / templates / voicemail / notify.php after the <? prompt: eg :
    error_reporting(0);
    .. rest of file here
  3. onekit
    Aug 3, 2007
    27
    I just begin trying to fix this bug by your advices, but bug disappear self. Very strange. :shock:
    That's my aura. Bugs attack me everytime. :D Every beta-test department loves me.
