php.ini - port 443
Discussion in '3CX Phone System - General' started by etm_ltd, Sep 10, 2007.
  1. etm_ltd
    Nov 18, 2006
    69
    We need to use our 443 port for https exchange server.
    This is used by the PHP.INI file for a section called [Verisign Payflow Pro]
    Does this is a future extension for 3CX PS or a basic setting for your PHP.INI? If so, what will be used for?
    Can this can be deactivated by a ; at the beginning of the line without configuration problem in future uses?
