PHP to connect to 3CX database
Discussion in '3CX Phone System - General' started by ryan, Sep 24, 2007.
  1. ryan
    Aug 27, 2007
    35
    Evening all,
    Is it possible to use PHP to connect to the 3CX database or is it that funny OBDC stuff only. Being a Linux guy I get confused if I can't code it !!
    Ry
