Pick up a call using BLF ?
Discussion in 'Windows' started by Cor i Luz, Feb 8, 2016.
  1. Cor i Luz
    Oct 28, 2015
    6
    I need a little help : is it possible to pickup a call with 3CX SoftPhone (clicking BLF doesn't seem to work) ?
    Thank you for your advice !
  2. tim942
    Jul 30, 2015
    68
    6
    I gave up on the BLF as the Presence/Switchboard is more functional. Right-click the extension/call (not BLF) and "Take" or dial *20*ext. You should also make sure you have the appropriate group rights enabled (Extensions>*Group>Member Rights).
  3. Lev
    Lev New Member
    Sep 19, 2015
    119
    17
    Maybe you should post this in the Ideas Forum. I'd like to see the softphones BLF Keys to work as the ones on normal hardware phones! :)
  4. AlexanderHanna
    Oct 2, 2015
    89
    11
    It does work. You have to use the "Custom Speed Dial" option and then the number should be "*20*" to pick up any call in the call group. I have implemented this in my solutions where required.
    Alexander
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,340
    77
