Picking up a call without Call Assiatant
Discussion in '3CX Phone System - General' started by eddietang, Dec 4, 2007.
  1. eddietang
    Oct 3, 2007
    31
    Is there a way a user can pickup a call from another extension without the use of the 3CX Call Assistant app? If there isn't such a feature, perhaps it could be included in the next version?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    By default the pickup code is *10*. It works at V3.
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    At my experience it does not work in v5.. yet.. :wink:
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Oh. I see. It's too bad.
  5. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hopefully it will be present in stable version.
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Mori,
    Have you try out BLF at V5? My testing not too good. It just working. But not stable. The status indicator not always in correct status :(
  7. Mori
    Mori New Member
    Mar 23, 2007
    223
    Sorry "5qg4"
    Have not tested it. :?
  8. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    default pickup code for version 5 is *20*
  9. eddietang
    Oct 3, 2007
    31
    I am using a Linksys SPA922 phone and I can't pickup using the suggested *10* sequence.
    We tried *10* <extension> [Dial] and [Dial] *10*<extention> and it does not pickup.
    Any suggestions what I may be doing wrong?
  10. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I believe that what you talking about is Call Parking, the *10* code is for example....
    Someone calls from ext 101 to 304, you hear that phone ring and you know there isnt anyone there, so you dial *10* on your phone and you will pick up that call....
    Cheers
  11. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    On V3 i configured manually to be 50 on the ini, but on V5 with our linksys and grandstream SIP phones we can pick another call with *20* but we have one fxs line with a SPA3102 and dont work with that.
    Does anybody tried changing manually on the ini?
  12. evdbovenkamp
    May 31, 2007
    5
    Answer
    Does anyone know the answer for V5 already? I tried *10*, *20*, but it does not work.
  13. AldoLinares
    Nov 12, 2007
    135
    What i did was adding the next line to 3CXPhoneSystem.ini
    [dialcodes]
    pickup = 50 (or what ever number you want to pickup)
    and its working
  14. silentfun
    silentfun Member
    Dec 11, 2006
    364
    what is about this case ?
    room 1 with 2 workers and two phones ext 101 and 102
    room 2 with 2 workers and two phones ext 201 and 202
    there are two diferent calls at the same time for ext 101 and 202
    and the workers at 102 and 202 want to take the phone call for their workmates 102 for 101 and 202 for that for 201.
    if they use the *20* or what ever they place in the ini-file. who gets the call for witch extension? I´m shure this is not the worsed case cenario.
    and think about that workers in room 1 can not hear the ringing in the other rooms! If they possible wait for a expectet call they possible say" Hi babe" to the CFO´s wife and get fired :)
    Andy
  15. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hmm.. propably a step back in the discussion, but what about using DR and ringgroups/queu to make calls fallback or frwrd to an available ext.?
  16. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    First off all in the current version by default its *20*. But if I am not mistaken this is a feature available in every non-free version
  17. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I am confuesed by this feature/request.
    What purpose is it serving? Is this a work around to shared line appearance?
    Why would you want to pick up another users calls, why not just let it go to VM or have the inbound call goto a ring group with all parties.
    I also believe that Call Parking would help in this scenario; however I have heard that this kindof works but have not tried it myself. Speaking of call parking does anyone have any info on setting it up?
  18. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Because:
    Maybe the user has a DDI (DID) which isn't in a call group, and has just nipped to lunch and their colleague has been briefed that there's an important call due in. Would you want to either (a) set up a call group for that one instance, or (b) let that important call go to voicemail??
    In offices there's always been a need to pick up a colleague's extension without using a hunt group.
  19. Mori
    Mori New Member
    Mar 23, 2007
    223
    If tis call is that important, how about this user just use the webinterface at http://3cxserver/myphone/user_main.php and set his line forwarding this to either his own cellphone, or his colleauge?
    It takes less than a minute changing this setting.
  20. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I agree, not to be smug but if the call is that important DONT GO TO LUNCH.
    But seriously, I think you need to step away from the old analog way of doing things and embrace VoIP. Clearly there will not be an apples to apples comparison for ALL features. I think the ability to transfer on the fly as previously recommended is a great alternative. Also what about transferring this extension to a previously defined Ring Group for the duration of lunch. Even if the Ring Group is usually never used just set it up for this purpose and transfer as needed.
