Pickup a call that rings on another extention ?
Discussion in '3CX Phone System - General' started by stamos, Oct 12, 2007.
  1. stamos
    Jul 24, 2007
    5
    How can I pick up a call that rings on another extention, without using Call Assistant ?
    I am using Snom 360 as a phone.
    Thank you
    Stamos Achtidas
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    If I remember correctly you pickup the phone where you wish to answer call and dial 9100. If more than one calls are ringing this will give you the first one. If you know the extension that is ringing and you wish that specific call you dial 9100+ext number. The 9100 can be changed by editing a file in 3CX, I just don't remember the details. If it works for you and you wish the edit info just post request and I will find it.
  3. stamos
    Jul 24, 2007
    5
    Didn't work with 9100 . I use 9 to get an outside line. If you remember the text file would be great. I will search also on the 3cx directory.
  4. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    You can do this by editing the 3CX ini file.
    See this post.
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/transfer-call-2121/
  5. stamos
    Jul 24, 2007
    5
    That worked. I have put
    [DialCodes]
    pickup = 6100
    on the ini file, restarted the 3cx system and worked .
    Thank you for the fast response.
    Stamos Achtidas
