Solved Picture shown in 3CX app
Discussion in 'iOS' started by Vaucluse, Nov 6, 2017.
  1. Vaucluse
    Sep 30, 2013
    14
    What picture is shown in the 3CX App? I have iOS and use multiple accounts.
    Are there specific search criteria for looking in the contacts?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    If contact's image is provided by the PBX, then that one will be displayed.
    If no image is provided by the PBX, then the main criteria is the eMail - that means, you may nave an extension and/or mobile in US, but a different ones in DE; so, if eMail is provided, it's checked for match in the device contacts and, if there is a match and image, that one will be shown.
    Vaucluse likes this.
