Pin Lock Yealink T20 Handset
Discussion in '3CX Phone System - General' started by instra4, Sep 15, 2011.
  1. instra4
    Aug 15, 2011
    Hi All,
    I am just trying to secure an extension in a public area on the system 3CX V10
    What i want to do is use a Yealink T20 and have the user be able to use the internal extensions as per normal but to dial out on an external call i want to put in a pin number to facilitate this just so that unauthorised persons cant dial out.
    Cheers
    Danny
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Search the forums - this is discussed many times.
    The basic idea is to use the prefix for outgoing calls in outbound rules as pin - like instead of dialing 9 1234567890 (9 is the prefix for outbound call and is stripped) to use something like 9 *1234* 1234567890 and to strip 7 digits (*1234* is the pin).
    Regards
  3. instra4
    Aug 15, 2011
    Apologies for not finding this. I did a fair bit of searching but couldnt turn up anything.
    Thanks for the response, i will try this and see how it goes.
    Thanks again
