PIN Number
Discussion in '3CX Phone System - General' started by Anonymous, Nov 15, 2006.
  1. Anonymous
    Anonymous Guest
    What is the PIN number under the voice mail field. Is the a number used to dial voicemail for checking purposes or what?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    The pin number is used to secure the voice mail box. If the user wants to dial into to retrieve his voice mail then this pin number must be entered.
  3. Anonymous
    Anonymous Guest
    I would like to listen to voicemail messages without having to enter my extension number and pin number.
    Is that possible, or is that going to be possible?
    I'm using 3CX private, for home use. Security, from the inside, is not an issue to me.
    What I'm thinking about is: when a user calls his/her own extension number, the voicemail messages are played (option for enable/disable). When calling 999 an extension number and pin number is required.
  4. Nick Galea
    Jun 6, 2006
    1,992
    308
    email
    in that case have your voice mail sent to your email and listen to them from there...
