PIN on phone SPA922
Discussion in '3CX Phone System - General' started by MasterX, Oct 6, 2010.
  1. MasterX
    Oct 2, 2008
    28
    hi morning,
    i want lock a phone when operator there isn't .
    i want that operator put a PIN o a code one your phone for use .
    can i create this?
    thanks
    11,117
    329
    I believe that if you set a numeric password for the USER (there are both USER and ADMIN passwords) and set the phone to lock after a given time, then you will have to key in that PIN to place a call . That is the way it works with one of the other Linksys phones that I use.
