PIN Protect for Long Distance Calls
Discussion in 'Ideas' started by tecskw, Feb 13, 2016.
PIN Protect for Long Distance Calls 5 5 1votes
5/5, 1 vote
  1. tecskw
    Nov 7, 2013
    6
    Was just confirmed by one of the moderators that the outbound PIN Protect only works for all outbound calls and the ability to only use PIN Protect for Long Distance calls is not possible.
    Would like the ability to configure phones to have the ability to do the following:
    1. Block all outbound calls - Currently works with PIN Protect, then any calls are made using outbound rules
    2. Allow local dialing - Currently works using outbound rules
    3. Allow local dialing but block Long Distance Calls unless code is entered
