Pin Security
Discussion in '3CX Phone System - General' started by craigreilly, Dec 9, 2013.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    We would like to see some rules on the pin. ie: Pin cannot be same as extension, pin must be atleast x digits long, etc.
    I tried putting a portion of this into Facebook ("Option to not allow VM Pin to be same as Extension #.") and received this response:
    "You can set the PIN to be the same as the ext it self. it will be a warning only and shown in red. if you dont meant this, then plz open a more specific feat. req."
    So I resubmited it ("In Settings/ General, an option that, when checked, doesn't allow uses to create a VM Pin the same as their extension. Also, a minimum length PIN option under Settings/General.
    Right now, I have to log in and see when someone has a weak password. Instead, allow the Admin to set a Global option that prevents this from happening.") and it has a whopping 5 votes. To me, this is pretty important.
    Any one have any thoughts on the importance of this?
