ping? source ip? 0.0.0.0 failed???
Discussion in '3CX Phone System - General' started by cs512tr, Jun 20, 2007.
  1. cs512tr
    Jun 20, 2007
    9
    hi all, i was hoping someone could help me, i installed 3cx and it works cool.
    anyway in the serverlog page i am constantly seeing this message lines below:
    Time Function Message
    01:29:22.673 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: 'ping'; To: ''; Rline: ''; Contact: ''
    01:29:16.964 StratInOut::eek:nHangUp Call(C:2E): Call from Ext.100 to 999 has been terminated
    01:29:13.810 MediaServerReporting::RTPSender from 'mailhost:0/MediaServer':EP 00000054@(PLAYFILE): Can't send RTP stream to 0.0.0.0:16410 destination unreachable
    01:29:11.376 CallLegImpl::eek:nConnected Call(C:2E): Created audio channel for Ext.100 (10.1.1.253:16410) with Media Server (10.1.1.250:7128)
    01:29:11.206 CallConf::eek:nIncoming Call(C:2E): Incoming call from Ext.100 to sip:999@10.1.1.250
    01:29:07.601 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: 'ping'; To: ''; Rline: ''; Contact: ''
    01:28:52.559 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: 'ping'; To: ''; Rline: ''; Contact: ''
    01:28:37.778 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: 'ping'; To: ''; Rline: ''; Contact: ''
    01:28:22.396 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: 'ping'; To: ''; Rline: ''; Contact: ''
    01:28:07.454 Endpoint::findSource Can not find source by following specs: Contact IP: ''; From: 'ping'; To: ''; Rline: ''; Contact: ''
    (note, this was snipped from the log when i attempted to call 999, and place it on hold, and retrieve to show whats happening)
    i also sometimes after calling and taking off hold, they cannot hear me, but i can hear them clearly...
    cheers
    Carl
    Hardware/Software:
    3CX installed on Server2003 SP2
    Router Netcomm NB5+4W (ports forwarded to server2003 IP)
    X-Lite softphone (X2)
    Linksys SPA-941 IP Phone, (latest firmare for all)
  2. cs512tr
    Jun 20, 2007
    9
    FYI !
    sorry should also add using:
    3CX Phone System v3.0.1928.0
    Carl
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    things are changed since 17-th of June... Please, setup new version. It is really better. there are few changes related to your problems.
    Thanks,
    Stepan
    P.S. You don't need to uninstall old version, you can simply upgrade it with new installation. But it is safer to backup you database first.
  4. cs512tr
    Jun 20, 2007
    9
    thankyou for that.
    i will backup and upgrade in the morning, well in about 7hours :roll:
    cheers
    will post results
  5. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    If i am not mistaken xlite phone must be bound to media server. And it doesn't support replaces. This would settle your one way audio problems.
    As far ar the other problem you have been having , as SY very correctly said, there is a new version, which we suggest you download. It is so much better and improved... I am sure you will like it and its new features...
    here is a list of new features for paid versions.
    http://www.3cx.com/support/buildhistory.html
  6. cs512tr
    Jun 20, 2007
    9
    Works well, but transfer issue?
    hi guys thanks for your support.
    i had upgraded to latest, and works well. :)
    one question though, when i transfer a call to an external number for example my home phone number. it will transfer ok, but the call quality is still dependant on my connection. i thought when i transferred a call, it then removes me (my 3cx system etc) from the connected call?
    am i missing something?
    Cheers
  7. 3CXsupport
    3CXsupport New Member
    3CX Support
    Aug 21, 2006
    193
    No, it is not transfered externally.
    This is a PSTN limitation. When you execute such a transfer the PBX is simply connecting two calls in reality.
