PINSETS
Discussion in 'Ideas' started by Pablo Sanchez, Oct 4, 2017.
PINSETS 5 5 3votes
5/5, 3 votes
  1. Pablo Sanchez
    Oct 4, 2017
    I have a client that uses Elastix, it has configured PINs of calls which are not connected to any extension, so any user can make calls from any extension just knowing the PIN number of call.
    It is possible to add this option to 3CX?
    Tengo un cliente que usa Elastix en el cual tiene configurados PIN de llamadas los cuales no están ligados a ninguna extension, así cualquier usuario puede realizar llamadas desde cualquier extension con solo saber el numero de PIN de llamada.
    Podria agregarse esta opcion a Elastix?
  2. Wilson Dario Maldonado
    Oct 15, 2017
    I send idea to send to the support of 3cx because the customers of telephone exchanges of other brands ask when they offer any of the versions of 3cx.
    The pinset is very functional to make calls from any extension of the telephone system with charge to a code.
    Pablo Sanchez likes this.
  3. Silly English Kniggit
    Sep 13, 2017
    220
    90
    True 3CX doesn't support call accounting codes - but I've never had anyone ask for them either.
  4. Jose Lara
    Mar 16, 2017
    23
    the Pin codes is very funtional, and much of the Asterisk clients uses this funtion to control outblound calls for destionations have aditional cost
  5. ODD Network BV
    Oct 24, 2017
    7
    All my 3CX customers are waiting for the Pinset.
    I have also 3 hotels that need this pinset.
    3CX, can you guys please implement the pinset. It is verry usefull.
  6. ODD Network BV
    Oct 24, 2017
    7
    Dear 3CX,
    What about the Pinset rule?
    Customers Still waiting on this feature..
