PIPEDRIVE crm integration
Discussion in 'CRM / Helpdesk / App Integration' started by carlo_hoayek, Jul 26, 2017.
  1. carlo_hoayek
    Nov 9, 2016
    5
    Was anyone able to integrate 3CX with pipedrive as it integrates with other cloud based phones systems? (thus enabling 3CX to create logs and call recording on pipedrive's client dashboard, or create a new contact or recognize the contact by syncing with pipedrives)'.....example attached.
    Im new to the CRM thing and trying to get full use of it.
    Thanks for your replies!
    Regards,
  2. GaryRoberts
    Aug 4, 2017
    Hi There
    Did you find a solution to this as I am trying to do the same?
    Thank you in advance
    Gary
  3. carlo_hoayek
    Nov 9, 2016
    5
    Hi Gary,
    No not really. No one from 3CX even replied to my thread.
    All other cloud systems support Pipedrive but this means i need to get rid of my local pbx and desk phones which im not willing to.
    If you get any way of doing that please let me now!
    Thanks!
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Hello there,
    Please note that Pipeline CRM is not supported by 3CX at the current time. You can however request it by posting a feature request in our ideas section of the forum or develop your own integration by following this guide: https://www.3cx.com/blog/releases/crm-integration-diy/
