Place voicemail on the main phone number of the office
Discussion in 'Windows' started by Screwdriver.dll, Jan 4, 2018.
Tags:
  1. Screwdriver.dll
    Jan 4, 2018
    Hi there,
    Is there a possibility to place a voicemail in the 3CX Management Console on the main phone number of a company with for example:
    'Hello, This is XXX and we are currently in a meeting for half an hour, please call back'.
    And i want to activate this on every yealink phone in my company, so every employee can activate or de-activate that specific voicemail for the main phone number. Is this possible with a BLF or something, or that every phone can call for example *101 to activate it?
    Thank you!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Hello @Screwdriver.dll
    You might be able to achieve the required functionality using the "Force 3CX Phone System to IN or OUT of office" dial code which should be set *64 be default. So if you dial *640 is the default office hours, *641 is the In office hours and by dialling *642 you can force the system to out of office hours.
    Please note that when you force the system with *641 or *642 the system will follow that status and will auto switch to in and out of office hours until you set it back to the default hours using *640.
    You can then use the main numbers In and out of office hours routes to control where calls will be forwarded depending on the status.
