Placing Outgoing Calls Problem
Discussion in '3CX Phone System - General' started by RonnyG46, Oct 2, 2008.
  1. RonnyG46
    Oct 2, 2008
    I'm new to VOIP. My system. Linksys SAP3012 VOIP GATEWAY, Linksys Router, Aastra 53i phones.
    At this time I ONLY have one PSTN line setup to use. NO VOIP yet. I want to get it running on the PSTN Line FIRST.
    I am able to call other extensions on network by using the EXT number.
    I am am to answer in-coming PSTN line calls and hear / talk with the person.
    I can NOT make outgoing calls. That's where I need help.
    I attached my phone log.
    Please help with any suggestions.
    Thanks for your help.
    Ron
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You need to set up an outbound rule as specified in http://www.3cx.com/manual/3CXPhoneSystemManual6/phone-system39.html
    regards
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    also you need to change port to 5061 in spa and 3CX
    also check the volt status
  4. tekknow
    Oct 3, 2008
    29
    I do not think this is sound advice. I think the only place to change the Port in 3cx changes it system wide, There is no need to change it if you have no conflicts on the system for that port.
    As for the SPA, any 2 Port SPA ships with the Local Ports at 5060 and 5061 , this is to avoid conflicts , and also a way of differentiating that a call goes to 192.168.1.2:5060 vs 192.168.1.2:5061. It is also useful for NAT mapping. This local port however has nothing to do with the server port. For instance when STUN is used, the local port may be 11103 while the remote server port is 5060. There is no need that they are the same
    The Volt status he refers to is the line voltage. You can use this as a rudimentary way to determine if the line is on hook or off hook. Off hook voltage is about 48V and on Hook is about 5v. Beyond that it is really not too useful for diagnostic purposes, unless of course you are rural and have a very long line loop, or are right next door to the Telco CO and it is very short, or perhaps on a system tghat does not conform so well to the norm.
  5. RonnyG46
    Oct 2, 2008
    I'm still unable to make an outgoing call. I added the Outbound Rule.
    Below I attached my >> 1. Server Status 2. Extension Setup 3. Line Setup 4. Outbound Call Rule.
    The Server Status is after I made the changes and tried a outgoing call.
    RonnyG46
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    I'm sory but Your words pushing me to say "I do not think you know spa3102"
    ports must be 5060 and 5061 on both ends
    I said check volt because the default volt to detect in spa3102 is 30 volts so if his pstn volt less than 30 he will never can do a call before modify it to 10 or 5
    when some one has small issue it means he has not enough experince
    so he needs simple ansowers
  7. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello RonnyG46,
    because of spa3102 dial plan change * to any number
  8. RonnyG46
    Oct 2, 2008
    I changed the dial rule from * to 9.
    Is that what you meant?
    Still no connection.
    In the report you can see that it sees the number with the 9 and then removes it, but the call fails.
    Attached is Server Status report.
    Thnaks for your help.
    RonnyG46
  9. galal202
    galal202 New Member
    Jun 23, 2008
    235
    reset to factory set and reconfig again
    do not forget pstn port in 3cx server must be 5061
  10. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    It looks to me like you are receiving a 404 error back from the gateway device. This would lead me to believe 1 of 2 things. Either your pbx is not registered to the gatway properly or the gateway device does not know hoe to route that number itself.
    Mike
  11. RonnyG46
    Oct 2, 2008
    Is there a way to check and make sure the DBX is properly registered to the Gateway?
    Another Ques: In the Aastra 59i SIP PHONE config > What address should be listed for the Proxy Sever? What device is this for?
    RonnyG46
