Planet VIP 153 PT and 3CX
Discussion in '3CX Phone System - General' started by rolf, Oct 5, 2007.
  1. rolf
    May 6, 2007
    13
    Has anybody tasted IP phone Planet VIP 153 PT with 3CX? As for me, transfer mode and music on hold does not work...
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    What do the Server logs show when you try to tansfer/hold a call?
    Please post that part of the logs.
    Cheers
  3. rolf
    May 6, 2007
    13
    - Call from Ext. 104 to ext. 101. When press "HOLD":
    13:39:45.734 MediaServerReporting::RTPSender [MS004000] Call(11)
    Ext.104: (ACTIVE): Can't send RTP stream to 0.0.0.0:10004 destination
    unreachable
    13:39:45.390 MediaServerReporting::RTPSender [MS004000] Call(11)
    Ext.101: (ACTIVE): Can't send RTP stream to 0.0.0.0:10106 destination
    unreachable
    - When unpress "HOLD" button:
    13:39:56.578 MediaServerReporting::RTPSender [MS104000] Call(11)
    Ext.104: (ACTIVE) RTP stream to 192.168.1.100:10004 restored.
    13:39:56.281 MediaServerReporting::RTPSender [MS104000] Call(11)
    Ext.101: (ACTIVE) RTP stream to 192.168.1.101:10106 restored.
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Same thing happening here
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/on-hold-music-doesn-t-work-2526/
    Read it and see if it helps you in anyway. Im out of ideas here...
    Cheers
  5. rolf
    May 6, 2007
    13
    Thanks for an answear! Ithink, that it is Planet's BUG...
  6. rolf
    May 6, 2007
    13
    ...Or 3CX's
  7. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    If its 3CX i dont believe its a bug, since may ppl got it working properly, maybe its some configuration here or there....
    Try diferent settings, see if you can change anything that can make that work. I believe thats more a configuration problem somewhere then a bug....
    Cheers
  8. LORD ORION
    Jul 23, 2007
    39
    Try
    1) Remove SDP change support on the extension
    If that doesnt work.
    2) Remove reinvite support on the extension.
