Play music on hold in queues always from the beginning
Discussion in 'Ideas' started by infohit, Dec 9, 2017.
Play music on hold in queues always from the beginning 5 5 5votes
5/5, 5 votes
  1. infohit
    Nov 21, 2017
    21
    8
    It would be nice to have an option, to set music on hold, or playlists, to always start playing from the beginning of the file.
    #1 infohit, Dec 9, 2017
    TEIN d.o.o. likes this.
  2. advanced25
    Aug 10, 2012
    19
    10
    We're having opposite problems! I'm finding that the default behavior is to always start at the beginning and I want to change it so that the callers are dropped in wherever the system is playing the file at that point in time.
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    894
    154
    My understanding is the first caller into a queue starts the playing of the wav file which then continues in a endless loop. Any new callers sent to the queue hear the audio based on where the audio is in the loop. There is no way to change the behavior.
  4. infohit
    Nov 21, 2017
    21
    8
    Exactly. It used to always play from the beginning in some older versions of 3CX. I'm asking for a simple checkbox to let users decide whether they want that or not.
    @voiptoys what version are you running that plays always from the beginning? Would you mind posting some screenshots of your queue config that's behaving this way?
