Play pre recorded message
Discussion in '3CX Phone System - General' started by Riaan, Sep 19, 2017.
  1. Riaan
    Jul 31, 2017
    6
    Hi guys,
    Is it possible for 3cx to play a pre recorded message. Lets say an extension calls an external number and a voicemail answers. We would like the agent then to press for example 1 on their softphone and a pre recorded recording should then be played leaving a message on the answering machine?
    Regards
    vizualpro likes this.
  2. vizualpro
    vizualpro New Member
    Jul 9, 2016
    115
    23
    Great Idea! You should post this in the "Ideas" forum for possible consideration.
    https://www.3cx.com/community/forums/3cx-ideas/
