Play wave but don't answer call
Discussion in '3CX Phone System - General' started by Kneza, Apr 10, 2018.
  1. Kneza
    Aug 15, 2017
    10
    I'm trying to solve situation, when I need to play some message, but don't pickup the call - for example something like "Called party is not available right now, because he is in meeting. Call later" and then End call.
    I'm using digital receptionist for this right now...
    2 things:
    1) is it possible somehow to play wave without answering call (like mobile operators do?)
    2) is it possible to log call like unanswered in cdr?
    Thank you
    10,112
    203
    You cannot play a message without answering the call (sending answer supervision back to caller). In many cases (SS7 type trunking), audio is not cut through, until answer supervision is received.
  3. voiptoys
    voiptoys Member
    Feb 13, 2013
    337
    66
    Yikes, you are speaking Greek to me leejor, but I concur with your assessment that there is no way within 3CX to play a message without answering the call. As a result, the CDR will show the call as answered.
    The assumption is, as you have stated, that you don't want voicemail as an option. Therefore, your solution to send the caller to a Digital Receptionist seems like the most logical approach.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,823
    138
    It is a great idea... and essentially, the call is being answered by a DR of sorts... that plays back the assigned/selected message.
    If everyone had a DR with a few programmable greetings, it could work.
    Inbound Call to x199. Receiver pressed DR1 button, and they get transfered to DR199 option 1. Message plays. Hangs up.
    And each option could have Take message YES/NO.
    Can't do this now... but its fun the think about.
    I've had this idea where my voicemail is DR. And in the greeting it can say "Press 2 to have me paged in the building.Press 3 to leave a message, etc"
    Call put on hold. Siri (or Cortana o_O ) says over a Ring Group/MC Paging Group: "recorded name" you have a call holding.
    With a message like that, user knows its on their personal hold. And can pick it up on *1<ext>
  5. Kneza
    Aug 15, 2017
    10
    I think, that DR should have some checkbox or something like that, which can say if it means that call was answered or not...
    Right now, with all calls ending with message, we have all calls answered, even it was just message, that recipient is not available ;-)
